Catalina 22 Aluminum Bulkhead Replacement
Sep 30, 2025
2
Catalina 22 Lake Conroe
Has anyone replaced the bulkheads with aluminum plate? I own a metal shop and thought that it would be a nice exchange since I have encountered some bulkhead damage in my vessel. Thinking it will add rigidity, and I can do the math where I am comparable on weight.
Peter
Texas
Sep 17, 2022
156
Catalina 22 Oolagah
That's an interesting question. You don't indicate what year or, model your C-22 is so, it's difficult to imagine what replacing a wood (and) trimmed bulkhead would look like in aluminum. Personally, I like the look of the Catalina OEM bulkheads. The look of the bulkhead's wood/teak trim brings a warmth to the cabin. It adds to the ambiance IMO. On the same vein, the PO of Waffle House replaced the teak handrails and outer trim with White Starboard. Also, the port bulkhead was replaced with a new bulkhead which does not match the starboard bulkhead in color or size. While fully functional and maintenance free, if I could ever source teak replacements to the Starboard, and also replace the port bulkhead, to match the original starboard bulkhead, I would do so in a heartbeat. I enjoyed maintaining the outer teak on my first C-22 immensely. Something to do while at anchor and the while rest of the family is still asleep. Sailing bliss.
Having said all of the above, the important issue is, have you corrected the root cause of the bulkhead damage? That issue needs to be addressed and corrected as if not corrected, there can be substantial damage to the deck if left unchecked. I hope this helps.
George
Sep 24, 2018
3,881
Catalina 30 MKIII Chicago
I'd be concerned about the resin delaminating from the metal. I've also found that wood is more likely to return to its original shape than metal after it's been stressed
Also if the chainplates bolt to the bulkhead you’ll want to do something to make sure the stainless hardware doesn’t directly contact the aluminum.
Sep 30, 2025
2
Thanks for the replies and I apologize for the delay; I can add to it.
1978 Swing Keel - The cabin with the settee to port and sliding galley to starboard
It is used strictly for racing and is already stripped inside so appearance and matching is not important.
I have not taken the boat out since damage was found and will be fully repairing or replacing any issue that could have caused this.
If I do decide to replace the bulkhead with aluminum plate, I will also be replacing and re-engineering chainplates to add rigidity.
I already make all my own stainless and aluminum parts that I replace on the boat, so I am no stranger to making things work. Replaced a lot of teak with starboard, glassed in the sliding top for strength, etc.
The metal and wood reaction to stress and return to shape is an interesting one. I have some extra aluminum that is 5083-O temper left over from a NASA job and it is frequently used in boat hull manufacturing. It has added strength and corrosion resistance.
Peter
