Be carefull with mast rake
Small changes (3/4 of an inch) at the masthead can have great effects on the sailing nature of a sloop. If your moving a properly rigged mast you can open the boat up to ills such as rounding up, unable to balance, not able to use Autopilots, and other ills.If you want to handle the mast alignment yourself, I suggest starting with the owners manual as it shows the exact rack for your boat. The size and cut (power) of your sails will have an effect on the balance of the boat and the rack of the mast. Basically, the farther forward the mast, the later it will round to weather as you moved the center of pressure forward, but it wont point as well as it could. Everything is a trade off.All stay's and shrouds should be under the correct tension, so if you tighten one, you may need to loosen the other and you should use a tensioner so you know where it is at.If you don’t want a livelong experiment, or just setting for the way things are, you might want to have a rigger check it out.Good luckBob
