Cat 30 blower
19
Catalina 30 Mesa, Az
Today I rewired the blower switch so I can run the blower without having the key on. Definitely a safety improvement.
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
Curious why you felt that needed to be one. What year boat do you have? Gas?
Jul 8, 2011
704
Catalina 30 Sidney B.C.
Why do you need the blower I have a 1982 with a diesel and only use the blower to cool engine comp fown on long engine journey
Jan 1, 2010
19
That is also why I use the blower, but why leave the ignition key on all the time.
Jan 1, 2010
19
I'll bottom line this: I run the blower before starting, during fueling, and after shutting engine off. The way it's wired originally defeats the whole purpose of the blower safety feature, energizing the starter circuit before removing fumes is not correct and I don't care what fuel it is.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
I'm thinking of adding a 120 vac muffin fan in the same blower hose so the fan can run all the time the boat is in the slip for ventilation. I do have a day/night solar fan in the main salon port but that doesn't seem to provide enough air flow.
Apr 4, 2004
78
Catalina 30 Ladysmith
I'm hoping that it was just a typo or a poorly worded sentence, but, running the blower while fueling is the equivalent of checking the gas tank with a lit match.
Mar 11, 2010
292
Catalina Tall Rig/ Fin Keel Deale, MD
Blower on the diesel is for ventilating the engine compartment while running to help reduce heat while assisting air flow to the air intake of the engine. I could also see a benefit to using it for ventilating the cabin while away, but we use a solar exhaust vent mounted above the vee-berth and then draw the make up air through slots in the companionway boards.
Rob
Fed up w/ personal attacks I'm done with SBO
Those with propane stoves, don't discount the effectiveness of using the blower to evacuate those potentially explosive fumes. Like gasoline, propane fumes are heavier than air and have similar explosive force.
And you dieselites thought you were safe . . . . .
Apr 4, 2004
78
Understanding the limitations of propane, some of us "dieselites" shun it and use CNG for it's lighter than air properties or, because of the "break" the insurance company gives us for using it.:stirthepot:
EG
Suckers, too
Blowers on boats with diesel engines are there simply because the builders forgot to take them out once gas engines weren't being installed anymore. :doh:
The fact that skippers got creative in the use of the now-remaining blowers (or suckers depending on your point of view :)) is a tribute to the ingenuity of those skippers. :eek:
jrowan
Mar 5, 2011
1,294
I always run my blower unit before engaging the glow plugs & starting the diesel just in case of any built up propane gas, or fumes in the bilge as Neil points out. You cannot be too careful, only too lazy. The idea of running it to cool down the cabin & engine copartment some after running the engine for long periods of time is a good one.
