Our Cat-25 is on the hard at Yachtfish Marine, Port Orchard, Wa. And an update on the continuing restoration.
An inspection of the keel hangar assembly ( I looked at close up photos my oldest son took) revealed that the hangar assembly was installed upside down. Had it not been for the information on this forum I would not have known that. When I brought it to the attention of the yard manager he said it was installed correctly. I sent him a Catalina drawing found in this forum and convinced him otherwise.
So upon removal of the keel the bronze pivot pin was bent and the pivot pin hole in the keel was elongated as well. The yard manager agreed with my theory that the keel cable failed with the keel in the full up position resulting in the interior damage. Further, it seems as if the keel was removed to help effect the repairs in the trunk and the bent pin was not noticed and the hangar assembly was installed upside down.
I ordered from Catalina Direct the upgraded hangar assembly, new fasteners, loctite, pivot pin, pivot pin bushing, and keel centering spacers. That will eliminate the keel klunk and make the keel assembly as strong as it can be. The parts are expected to arrive 1/10/13.
