Ted Derivan
I purchased a 1980 Catalina 25 in July. The seller had not used the water since the previous season (fall 99)He did winterize it with some kind of red antifreeze. After I filled the tank from the dock, I had a lot of red water coming out of the sinks (2). These are manual pump sinks so it took a while to get it out. The color is no longer red but there are black flakes of stuff that comes out. It is worse after the boat sits at the dock for a while. Is there any way to drain the water out of the tank and lines? I would also like to put a larger inspection hole in the tank (maybe four or five inches in diameter), any ideas on how to do this?
