removehtml] have a 1982 34 oday with a cast iron keel with what I believe to be monel bolts and nuts. The keel appears to be moving, albeit a very small amount. The evidence that leads me to this conclusion is the seam between the keel top and the fiberglass stub it is attached to seems to open up enough during the season to permit rusting along the seam. This happens after the seam has been opened up in the spring, cast iron touched up and faired back in with west system. Eight months later, a nice rust ring around the joint. Questions posed are: Retorqueing the keel bolts may help but what is the proper torque? I have seen values suggested up to 300 ft lbs.The seam compound may be beyond it's useful life and hence retorqueing may be futile. Has anyone experienced retorqueing only to break a keel bolt? The dissimiliar metals used concerns me.Finally, has anyone removed a cast iron keel to rebed, refinish etc successfully with out with out spending one's wallet down to the bottom?Any comments related to these topics would be most appreciated as I am taking the boat to maine this summer and like piece of mind where keels are concerned. Thanks!Fred Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
