cast iron keel
marty gelbard
Periodically I've sanded down the cast iron keel on my O'day 37 and applied epoxy. It seems corrosion starts where it is faired to the hull. I think perhaps I need to have the boatyard drop the keel, make sure the stainless steel keel bolts are in good condition, sandblast / recoat the keel then bed it back to the hull. Has this worked for anyone out there? Is this overkill? thanks.
May 6, 2005
35
Hunter fractional Port Sanilac, MI
Iron oxide
I am interested in the experts opinion on this. However, as I understand it iron froms it's own iron oxide film and that film will prevent further oxidation for a very long time (example iron sewer pipes in Rome from the time of the Roman empire). I would suspect you are creating an oxidation issue by "cleaning" the iron down to the point when it is "shiny". Experts?
