I used the POR15 system on my H23 keel. Decent, but I do have some rust spots and blisters after a few seasons (some appeared after season 1). I am in a fresh water lake. I used an angle grinder and coarse wire brush plus grinder wheel, not sand blasting. I did use their entire system, cleaner and prep, and followed directions as best I could. The success is probably somewhat sensitive to your skill, and it may truly require sand blasting. Though, they claim that a bit of non-scaly rust is no problem, as the material is supposed to convert the rust and bond to it.
