E
Ed Schenck
After several measurements I ordered a Raritan Cricket to replace the old ?? head on my H37C. The original head had a mounting pattern that was wide(12"?) and not very deep, around five inches. On an H37C the Cricket sits nicely on the platform but the rear lag bolt must go as far back as possible if you don't want the front hanging over the edge. In fact I was able to use the left front(forward/port) mounting hole. Had to drill two new ones. Now have to fill three old ones.Problem is that the water inlet is a straight 1/2" tube out the back on lower left. It's almost against the back leaving very little room for the hose connection. In fact mine has a minor kink that I hope will not affect the flow. Practical Sailor rated this highly for an inexpensive head. But I should have gone with the PH-II which has a very similar mounting to the original.Oh, and getting the hoses off and back on to the vented-loop?! Thanks for the hair dryer tip Peggy. With all that heat it was still a two hour job, just getting the hoses on and clamped.
