Bob Howie
In a previous forum question I inaccurately made the statement that propane, when it burns, does not produce carbon monoxide. I was wrong.In fact, any fossil fuel, regardless of type, will produce varying amounts of carbon monoxide, hence the importance that all spaces be properly ventilated and the heating source itself be properly vented when propane is being used. Typically, sufficient fresh air flow into various areas being heated by fossil fuels prevents dangerous build ups of CO. Quality and relatively inexpensive CO monitors -- which are generally available everywhere -- should be used and properly maintained.As a rule, however, propane and CNG burns cleaner than diesel or kerosene, provide longer burn times and don't generally produce as much CO as other fuels and can provide a wider margin of safety in their use.While I remain a proponent of safe and efficient use of propane aboard ship, I do stand corrected on the issue of propane and its generation of CO. I apologize for my inaccurate information which just goes to show that regardless of how right one thinks he might be, from time to time, one can be wrong.
