CSR does include resistance to capsize too
Doug, From what I have read, the Capsize Screen Ratio has two major parts. The first is the risk of being unduly easy to capsize, the second being the risk of being stuck in the inverted position for an extended period. This comes from the 1985 Final Report to the Directors - results of the SNAME & USYRA studies into yacht design triggered by the 1979 Fastnet. I agree that it has little to do with small boat sailing, as most any boat with a waterline of less than 30' is at great risk of capsize in breaking ocean waves. Length over this does not guarantee safety from capsize either, but generally speaking, boats over this size criteria can begin to develop values under 2.0., unless they are very wide in beam and/or light in displacement. The beamy-light combination gives a shorter "capsize length" than the actual measured waterline. Small boats inherently cannot produce the stability to score well on the screen formula Maximum Beam / Cube root of Displaced Volume. That is one more reason to pay attention to Small Craft Advisories. Steve
