capsizing a Daysailor
dpo628
Aug 23, 2005
3
- - Scarbrough
So Im new to having a Daysailor II. So heres a stupid question. How easy is a Daysailor to capsize? And when it happens, how hard is it to get back up?
May 12, 2004
165
- - Wasagaming, Manitoba
try to stay upright
I have owned and sailed a daysailer for 4 seasons now. A mentor of mine always encouraged me to sail with the sheets on my lap, and preferably in my hand with the other hand on the tiller. The sheets can be cleated. I sail single handed most of the time. Whenever the wind starts to blow it over, the first place water will come in, is over the leeward quarter. Sitting higher on the coaming will help it back upright. Either turn into the wind with the rudder, or release the mainsheet somewhat, and the boat will upright itself again. Ignore this warning and prepare to go over! I have never ignored this warning, and have never gone over. I note others that have however, and according to their testimony, the boat will fill with water and swamp, but will at the very least float at the gunwales unless you have loaded it down with motor and gear past its floatation capability, at which point, it will sink. Assuming you have only swamped it, and it has not turned turtle, it will likely be bailable, sea conditions permitting. If however it turns turtle, you will likely require other boat assistance to right it. If you are lucky, you may be able to step out onto the cb as it is going over, but if you are that intuitive, you would likely have already released the sheets and turned into the wind, preventing the need for standing on the cb to right it. The danger is moving around the boat with the sheets and tiller cleated, during gusty conditions or a strong blow. Your weight shifts the trim of the boat so that the center of lateral resistance moves forward or back, causing you to either round up or fall off from your course. Either way, the amount of power changes, and places you in a position to heel excessively. If you must cleat and leave, then hove to first, or put the boat into irons.
dpo628
Aug 23, 2005
3
- - Scarbrough
Thanks!
Thanks..I sailed on a sunfish alot years back and always had the sheet in my hands(no choice on a sunfishLOL!) so I think that habit will hold true with my daysailor. I think I only capsized my sunfish once, and that was the first time I used it. Hopefully wont have that problem with the Daysailor as its alot more boat to upright that a Sunfish!
Jul 13, 2005
18
- - Rensselaer, NY
Use Precautionary Measures
I have had one for 15 years and never capsized but filled it once halfway with water when it tipped and water came in the aft lee quarter. My buddy and I were looking at these hotties on a dock and forgot the wind was gusting haha. We sailed it back to the dock (slowly) bailed it and went out again. I would never want to capsize, too big of a boat to upright in water. So if it starts blowing hard enough to worry about that, then reduce sail area, ( reef the main maybe take dn the jib. Bear off the wind a little and hold on to the main sheet to let it out in gusts. Consider calling it a day.
