Limit of Positive Stability
Here is a web site that will help you calculate the approximate limit of positive stability. http://www.sailingusa.info/cal__avs.htmBeam = 8.9166 (8' 11")Displacement = 3748Ballast = 1433Hull Draft = 1.7' estimateplug this into the formula and it tells you 128.61 degrees of positive stability.This formula does not take into account the location of the vertical center of gravity. Dince the keel is low and deep I would guess that the true LPS is probably a little higher.The formulas on this site are great. Also check out Sailing Calculator http://www.image-ination.com/sailcalc.htmlGil
