Rolling
The O'day 22 is balasted, so it should take more than just wind to tip it all the way over. That said - its not quite impossible. Big wind alone is not the issue, the issue will be big wind combined with beam seas. What you want to be on the look out for is steap or frothing waves hitting you from the side at the same time as a big puff.If the boat does tip it will depend on whether the hatchs are closed and the hatch boards in place. If so, the cockpit will drain. If not you could get water below - that will make the would hard to control.They key is to watch the beam seas and keep the hatches closed in big weather.Justin - O'day Owners' Web
