Turtles, turtles everywhere
I am glad (somewhat) to see that someone other than me can turtle the 170. I thought I was the only "talented" one out there. I turtled my 170 a month ago while lake sailing. I posted a complaint of sorts in this forum and got similar advice as posted here. It made me, shall I say, rather upset.As I said then, I am tired of all of the "sage" advice about avoiding overheeling and turtling the 170, with the clear implication that you have to be an inexperienced idiot to turtle the 170. I am not inexperienced or an idiot. I have had the 170 for 2 1/2 summers now and sailed an O'Day Javelin for 12 years before then, with other boats before then. I have repeatedly had problems with the 170 overheeling.All the "great" advice about how to avoid over heeling and turtling, I think, is coming from people who have NEVER sailed the 170. As wide as it is, it heels very easily, and when tipped over, it will turtle. I still think there is a design flaw, which is easy to remedy. My Javelin had a heavy metal centerboard. I never turned over in that boat, even though it was much narrower. And I sailed in just as strong winds. I am lobbying for Hunter to recall the 170 to install a weighted centerboard.Since that is not likely to happen, I have, as suggested in a response, put a flotable fender at the top of the mast and tied some floating yellow rope to the top of the mast. The fender, I hope, will keep the boat from turtling. The new rope will help in righting the boat if (when) it turtles. Since it floats, I won't lose it straight down to the lake bottom, and since it is yellow, I will be able to see it easily.I believe that when tipped on its side, the boat will automatically turtle (unless you grab the mast real fast or have flotation at the top of the mast). The only time that you will tip over is when the wind is abeam. Since the boat is so wide, the boat, sticking that far out of the water, acts like a sail, and the wind will turtle the boat easily. Flotation at the mast top is the only answer.As far as righting the boat once turtled, forget it unless you can pull up the mast top (with a rope), or do as I did (ug) take the mast off, drag the boat to shore and flip it on the beach.I also wish Hunter had put a reefing point into the main as standard equipment.I do furl the jib when a gust comes. That does help.Because of the overheeling, my wife and daughter refuse go sail with me.
We all like to get advice from those who "know", but on this one, if you haven't sailed the 170 in a strong wind, keep it to yourself, cuz you don't know, really you don't.I like the 170 and am not about to give it up (yet), but I do believe that the design needs improvement. I wish Hunter would take the initiative.
