CSR
Stability is a dynamic event and is affected by quite a number of different vessel parameters.The Capsize Screen Ratio method has little value in the assessment of a yacht's dymamic stability. It's really addressing a concern that lightweight designs, with a wide beam, are suspect regarding their susceptibility to capsize. The cutoff number of “2" is based on the performance of boats in the '79 Fastnet, and is an arbitrary determination that takes no account of hull shape or ballast location, etc.STIX is the Stability Index, derived by the new International Standard for the stability and buoyancy of boats. STIX is calculated from the physical characteristics of each boat, and is a number generally in the range 5 to 50. Most data is derived from the GZ-curve**. A higher value suggests greater seaworthiness.The International Standard defines 4 Design Categories for boats broadly related to ocean (A), offshore (B), coastal (C) and local sailing (D). Each design category has a minimum qualifying STIX value, and also a minimum qualifying AVS* which is linked to the minimum sailing weight of the boat:* The “AVS” is the Angle of Vanishing Stability, also known as LPS, or Limit of Positive Stability. It is the angle beyond which a boat becomes unstable and will capsize to an inverted position.**The GZ-Curve is the Curve of Righting Arms. The Horizontal distance between the boat’s Centre of Gravity (CG) and a vertical line through it’s Centre of Bouyancy (CB).The curve is usually expressed in feet or meters along the vertical axis, and in degrees along the horizontal axis. With the vessel upright, the curve is at zero. As the boat heels, the center of buoyancy moves outboard, while the center of gravity remains stationary. This creates a Righting Arm or Righting Lever. It is the horizontal distance between the upward buoyant force and the downward force of gravity. The Righting Moment at any point on the curve is simply the product of the righting arm at that point (length) times the vessel's displacement (weight). In other words, Force times Distance equals Moment.
