Builders hide a whole world of data
It may be that no one has calculated the limit of positive stability for the Hunter 450. It is not something that has to be calculted in the process of designing the boat. If the Hunter 450 had ever raced under IMS, the rating certificate will give one version of the LPS, calculated from righting arm measurements of the boat raced. Be careful of comparing LPS values, unless you know they are calculated in the same way! The sad thing is that there is a world of data that IS part of boat design that designers and builders typically keep secret. For example, designers have to calculate the righting arm at small degrees of heel, to know that the boat will stand up to its sail plan. The designer must know the center of gravity (CG), and the center of buoyancy (CB), the latter at different angles of heel. The center of effort tells where the sails work, and the center of lateral resistance (CLR) tells where the hull pushes back. The former is easy for anyone to calculate from sail plan. Wetted surface (WS) tells how much resistance the boat has at low speeds, and how many gallons of antifouling you will need to buy. Then there is prismatic coefficient, polars from a VPP, etc. And that's just hull and sail abstractions. On top of that, there are the engineering data on how the boat is built: lamination schedules, the steps used to join parts, plumbing and electric schedules, etc. Finally, there is data on how the boats generally, and how a specific hull, varies from the design and engineering specifications.Production boat builders have a book of data on each model they produce. But they are NOT telling you, the buyer. Why not?
