Heeling
I've never sailed a 23, but I do have a 25. Mine sails best to windward between 15 & 20 degrees of heel, but I have sailed it at about 30. If you're heeling alot in 5 to 10 knots, two things come to mind:1) Your sails are blown out changing the draft of the sail to the point where the boat heels excessively2) You're new to sailing in general and have not yet gotten used to the heeling aspect of a sailboat.For the first, you can either have the sails recut or buy new sails. There is no greater performance increase than new sails. You will find you will sail flatter and faster.For the second, only experience will settle your nerves. But I can offer this fact, although I know it can be tough to remember when you're on the water and heeled. A keelboat CANNOT tip over. The laws of physics will not allow it.Actually, this is not 100% true. Most boats can right themselves 'heeled' as far as about 100 degrees (mast under water). This is termed Static Stability. Since you're unlikely to sail at 100 degrees heel
, capsizing is not an issue.Also, after the 1979 Fastnet (ocean race) fiasco, the governing bodies developed an empirical metric known as capsize risk. Intended for ocean racing, boats with values over '2' should not compete in such races while values under '2' are considered good. All O'days (except the 22, 28 and 290) have values under '2', yours being 1.97. So based on this metric, we're also looking OK.Now don't get me wrong, boats can be 'knocked down' by a large gust of wind that will put your spreaders in the water or you could get hit by a freak wave (which I doubt you'll find on Lakes Mendota/Monona). But capsizing or tipping over? Don't worry.In short, go sail, have fun and learn. Learn to read the water so you can see the wind gusts coming, learn when you need to shorten sail, learn to read your sails, etc. BUT ABOVE ALL, HAVE FUN.Russ
