Capri C-15 Coronado parts needed
Dec 8, 2024
1
Catalina C-15 Coronado Lake
Hi, I'm restoring a Coronado C-15 that has been neglected for years. I need help finding a few items:
1) Centerboard Gasket along with the trim that holds it in place.
2) Rubrail, or hull joint that has broken apart.
3) Centerboard stopper.
Any advice, or pointing me in the right direction would be really appreciated.
Thanks
Rory
Rub Rail
Rubrail
Centerboard gaskets area
Seal on top of centerboard gasket
Centerboard gasket.
Joe
Jun 1, 2004
8,125
Here's a parts page from CatalinaDirect.com There is also a customer service department at the Catalina Yachts factory. There's no website to my knowledge but you can contact the department through the general switchboard number that's posted on their website www.Catalinayachts.com
The gasket looks like a piece of Dacron sailcloth. Flying Scot, Inc may be able to help you as they use a similar method.
At least on he Scot the gasket is held in place by a piece of brass ½ round trim. Check McMaster-Carr
Early builders often appropriated parts from other industries. You might have luck looking through the CR Laurence catalog for vinyl trims and glazing vinyls.
Rub rail is different that the hull joint. Check Taco Marine for rub rails. They are a primary manufacturer of the rub rails.
The hull joint if damaged will need to be rebuilt.
-na -NA Anywhere USA
Coronada was purchased by Catalina if memory serves me right. Contact Skip at Catalina In Largo Florida who can steer you to the right person if possible
Otherwise, contact Catalina Direct which is not owned by Catalina who has helped Coronado owners in the past.
