Capri 26 low pressure alarm
76
CATALINA 28 MK II MONTREAL QC CANADA
I have a Capri 26 1991 and the module that sounds when you start the engine is out of function. I found an alarm module both for low oil pressure and high water temp. but I don,t know if there is a place on the oil line or elsewhere that I can connect a wire , same thing for the water temp.I don't exactly know if the old module used to buzz for temp or low oil pressure. So I'm not sure about the wiring Can anyone give me a clue on this.
Thanks
