Either will work, but the boat is already set up from the factory to lift the boat from the keel with a simple lifting harness. We basically copied the lifting harness from her big sister, the Capri-22. They share so much in common anyway, might as well lift them the same way too. Best of all, the harness stores under the cabin floor in the keel sump when not being used. :dance:
Don
