Motor for Catalina Capri 16.5
Key question would be where do you use your boat? Power requirements would be different between small lake, large lake, versus ocean. I just purchased my 16.5 recently and acquired a slightly used Tohatsu 2.5 HP. Nothing special is needed outside of the optional motor mount which if you don't have is a pretty inexpensive option that you can get from Catalina. (maybe $100).I'm sailing small to medium sized inland lakes and find the 2.5 as quite adequate for my needs. This model has just an internal gas tank which should run for about 35 minutes at full throttle, but I never need to run it that high. I also find the motor nice and light (only about 35 pounds) which makes it easy to take on/off for trailering. It's "bi directional" with a forward direction, and it rotates a full 180 degrees for reverse. With the standard motor mount from Catalina, the 180 degree swing is not a problem as it easily clears the transom and rudder. The only drawback is that it doesn't have a neutral "gear". A slightly larger (but more expensive) motor would include this gear.Ed
