cant start engine...glow plug and start together..
boatguy
engine wont start...when I push in glow plug and start at same time nothing happens...any ideas. Thanks!
Glow and Start
...buttons DO NOT need to be pushed together at th same time. Push the glow plug to warm up the plugs. Release the glow plug button. Then push start.
G
Gene
Start?
Want to make sure I understand your statement, are you saying when you have glow plugs on the starter woun't turn the engine over. If this is true, this show you have a low battery or there is a bad connection on the wiring circuit to the starter. Would think it is the main power wire or main ground, not the ignition switch circuit. Gene
