svwalkabout
Well...
Where to start... I can't eliminate the lee helm problem that I seemed to have built myself into. Here is what I have done / changes that have been made to the boat this year versus last year. I am wondering if I have too many things going on at once to be able to isolate the problem.
New standing rigging:
Standing rigging has been replaced and I know that the forestay was cut too short and as such, I have put the old one back on.
New rudder:
Changed the rudder profile a little bit but have gained control and responsiveness. I have also apparently decreased drag as the boat is faster upwind. The rudder is not underhung and does not wander when left unattended when under power with the outboard.
Sail modifications:
Changed the top 3 battens to be full battens instead of partial battens. I did this on an old sail to see if when I order a new sail next year if I will like full battens.
The problem presented itself this year when I was sailing in 12 - 15 knots of breeze and I let go of the tiller for a brief moment. The boat went from beam reaching to running really quickly (about 4 sec) instead of rounding up. I currently have 3-5 degrees of lee helm instead of 3-5 degrees of weather helm. Not good and not safe either...
I have been experimenting with forestay length and thus far have added length to the forestay (by way of an additional turnbuckle at the bottom for adjustability) and raked the tip of the mast back an additional 18" just to get a neutral helm. I am experimenting with the turnbuckle to determine how much length to add when ordering another new forestay.
From where I sit, this seems excessive and I am beginning to think that I have Gremlins on the boat.
So here are the questions that I have:
Can a new rudder shape change the balance of the boat?
Do full battens add Lee Helm?
Any one have any ideas on how to balance this boat and get a little weather helm?
Thanks in advance!
New rudder:
Sail modifications:
Thanks in advance!
