In ask all sailors, tried as "attachment" link below compose window and as the picture button in the formating bar and got the attached errors ...... When I try to attach the boat issue pic (even in this post), I get the errors in the screenshots but I can attach the error screenshots - so what does the forum not like about the pic of the certain boat issue?
- the post I wanted to make -
Fiberglass hull with pot marks at waterline -fix?
What the picture shows is the result after seller removed barnacles.
What is there to know about this waterline condition - how serious and what would it take to fix .... and does it even get fixed to be structurally sound or is it just cosmetic?
It has been suggested it is just in the antifouling layer(s).
For those that have dealt with this - Is it likely just in the anti-fouling or could it be affecting the gel/fiberglass?
It a solid non-cored fiberglass hull 1974 Paceship PY23
Looing at this hull as a replacement for my hull that has several deck soft spots - replace vs. repair...though I know I'm likely to get other condition "surprises" I'm starting with this obvious one to determine if it is a deal killer.
Thanks in advance for your input on this condition I know nothing about.
