Can you reef a Roller Furling Jib
Steve Carpman
Bill, We are having a new jib made and would like some advice on what can be done to make this new sail a roller reefing and furling jib. As I understand the problem, the concern about reefing on a roller is the additional sail material (required to give the sail draft)in the center of the sail. When reefing the jib on a roller, this additional material does not roll up the same as the top and bottom of the sail. The resulting shape is poor which not only impacts sailing ability but could possibly damage the sail. My research to date has disclosed two possible ways to overcome this problem. The first is to add some line (maybe 3/4" dia) in the middle 50-60% of the luff, just aft of the bolt rope. The purpose of this is to cause more of the center part of the sail to furl with each turn of the roller. The second way is to add foam to the luff, which I believe (although I am not sure)facilitates a more uniform rolling of the sail around the headstay. The negative of these two proposals is shape at the luff. While I do not race, I try to maximize performance. While there are other concerns present in reefing a jib (length of the genny track, reefing patches, etc), my question relates to the benefits obtained from the line in the luff or the foam luff. Do these techniques actually work? I guess another question is "Is roller reefing a jib, maintaining sail shape and not damaging the sail feasible." Steve Carpman
Bill Colombo
Luff Pads
Steve, Luff Pads do work quite well. The pad, whether rope or foam, increases the diameter of the roll in the middle section of the sail and thus takes up more cloth per turn in that area. I don't feel that they have a negative impact on sail performance, except on really small boats(under 24ft), where we don't recommend them. Foam works very well up to a point(75ft). Rope seems to work just as well though it is a bit bulky on smaller sails. There is no damage issue, in fact the pad creates a smoother overall furl and actually minimizes creasing that can cause sailcloth damage. Thanks, Bill Colombo Doyle Sails
May 18, 2004
385
Catalina 320 perry lake
luff pads
Can existing furling genoas have the pads added? If so is a very expensive retrofit. I have a 135 on my Oceanis 281. The sail is about 9 years old and was reconditioned by SailCare last year. It looks to be in good condition.
Bill Colombo
Luff Pad Retrofit
Bill, Yes, a luff padd can be added to an existing genoa. Any reputable sail loft should be able to do the job. We charge $6.50/ft. Thanks, Bill C. Doyle Sailmakers
