Hi Bill, I'm not sure what data you base your...
conclusions on, but to me running our 4JH propulsion engine for an hour that will consume about 1.5 gallons of fuel just to produce hot water, when the Genset can do it in the same amount of time, but consume about one half gallon of fuel, seems more economical.We use the inverter quite a bit while on the hook to power several AC appliances (microwave, TV/VCR, Walmart DVD player, stereo system, etc.) and in the past five years we have yet to have any of these units fail. Maybe some day they will, but I question whether it will be a result of operating them via the inverter. Ours is a 1991 model and all of the equipment (except for the DVD player) is original.As far as AC goes it has its place on a boat. Our boat came equipped with dual reverse cycle heat pumps. Maybe there is a DC or fuel version made, but these units are pretty efficient and do require AC to operate. Me thinks Hunter did the right thing in the systems they put together for this boat. At least I'm happy with the end product.TerryP.S. You are right that fuel stoves do a better job on a boat than AC.
