There may be a friction screw behind the steering wheel.
Just above center...
Also, the cable may be locked up if it's been sitting in the weather.
Disconnect it from the rudder/motor so you can see what is moving and what is frozen. Motor being locked up is rare but could happen if badly neglected.
Probably the steering cable, but best to check the easy access stuff first just in case.
