Can it be Re-built?
K
Kevin
I have a cold plate with a horz. evaporator. All componets appear to work except the system wont keep pressure. I was told that I have to trash the system and start over. Can it be re-built? Help! Thanks, Kevin
Phil Williams
Rebuild
Anything can be rebuilt. The question is how much will it take to do the rebuild. If the ColdMachine does not hold pressure it can be a small leak in the copper tubing, easy to fix. You can return the system to the Adler/Barbour factory for evaluation and repairs or have your local dealer fix it on the boat. If you would like to talk with one of our technicians about the choices please call 860-664-4906 and ask for refrigeration service.
