Can anyone help me???
1
Hunter HUN20043M83F -
My wife and I purchased a Hunter 20 online and we are trying to restore it. Our problem right now is that we had to take the swing keel out because the cable that lets it down was broken...It seems as if someone previously replaced the cable with the wrong kind of cable. The crank inside the cabin only cranks one way; like the crank on a boat trailer...is this correct? Any help would be very appreciated.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Like a boat trailer winch, it should have a release latch so you may lay out the line or wire. Check for a small lever that will flip up or down or a latch that can be manually lifted. It will directly engage the teeth on the drum.
