Capsize
Amen, Steve! We've been out on the Barnegat Bay in winds over 20 knots. It's not allot of fun! Our 23 has only one reef point, and we've been using it quite a bit lately! We also douse the jib (the stock jib is a 110% genoa) because it's just too much. Now we (and you!) can see the value in a storm jib! We try to keep the heel under 25 degrees; it's much easier to manage, as Doug has already mentioned.Also, when the winds and seas begin to pick up it's wise to batten down the hatches just in case the impossible does happen! We all know that the boat SHOULD right itself, but I don't know if it'd happen if the hull was full of water! One thing we never thought about until reading about it here is the lazarette hatch in the cockpit! It has no latch to keep it closed. If you ever did get blown over, even with the cabin sealed your 23 would fill up in seconds and it'd be all over! We now have twin latches there just to be sure! While we're on the subject, I'm sure that most, if not all, H23 owners know how heavy she steers on a run with 3-foot following seas (Barbara's done within 15 minutes of manning the helm!). If you watch the upper metal part of the rudder that surrounds the tiller, you can actually see it flexing. When we first got the Lil' Wass Ett, the tiller broke off on our third day out! It seems the wood around the pivot bolt was rotten and it couldn't take the strain. Luckily, the winds were only 5-10 knots that day! Since then, I keep a sharp eye on the condition of the tiller at that point and put it inside during the winter. That kind of excitement we can do without!Jim MaroldoOcean Gate, NJ
