Just bought an O'Day Daysailer 1 built in 1956. She was named Nancy Lee, and raced off Cape Cod and Salem, MA. Some readers may know this particular boat? There are several things I don't understand about it. Some are original; some may have been added by various owners.
Thru-fittings on coamings
I downloaded an owner's manual that illustrates how to run the jib-sheets: across the top of the cuddy (inside the shrouds) then to blocks on the inside of the coamings, thence to fairleads and cam-cleats mounted on the centerboard trunk. Fine. Altho I fail to see why the blocks on tracks on the coamings can be adjusted fore and aft about a foot. Can't see what difference that could make. However, there are original metal fittings in the coamings that are located such that one might run the jib-sheets thru them then outboard to original cleats. As if maybe the blocks in tracks were not original equipment in 1956. However, that routing would seem to induce a lot of friction at the thru-coaming fittings. Maybe they are for something else entirely? Any ideas? see photos
There is a jam cleat on the centerboard trunk that I fail to see the point of, since the jib-sheet hardware includes two cam cleats.
Fittings on mast
There is a pair of fittings on the mast just above the tangs for the forestay and shrouds. One port, one starboard. I have no idea what these are.
Masthead
There's a fitting at the masthead where the mainsail cable halyard exits the sheave. I think half may be broken away. I have no idea what purpose this would have served.
Mainsheet rigging
There is a bridle at the stern referred to as a traveler. I have seen similar arrangements on older boats. There are no controls. The boom will always move leeward of the centerline of the boat. My hypothesis is that early designers believed their boats would sail better. or safer this way. I owned a Town Class boat with a brass "traveler" shaped like a towel bar. That practice seems to have ceased.
But aside from the so-called traveler is the mainsheet rigging. The manual shows the bitter end fastened to a becket on a block on the end of the boom. Then down to a traveler block, then back up to the block on the boom end, then forward to a block sort of mid-boom, then down to the mainsheet block-with-cleat. I'm calling this a 2-part tackle, giving a mechanical advantage of 2:1' This puzzles me. My Cal 21 has a 5-part mainsheet tackle, and in winds above 20 mph, that's not enough for me to sheet in. I have to bear up to depower the sail before I can sheet in. So how can a 2-part tackle be sufficient?
I admit I have yet to sail this boat and maybe I will discover that for unknown reasons a 2-part is all that is needed. I'm skeptical. Won't be hard to convert to a 3-part or more tackle.
Any information you can offer will be appreciated.
Thanks,
jim
Fittings on mast
Masthead
Mainsheet rigging
Thanks,
jim
