Peter Milne
At the top of the anti-siphon loop in my raw water intake circuit, there is a 1/4' plastic tube attached which leads to the bilge. When the engine is running, at least one gallon per hour flows through the tube and into the bilge.Is this normal and if not what could be causing it to flow this much? The engine is a 50hp VolvoPenta.Thanks in advance.Peter MilneS/V Blue Heron
