making a bimini
After getting prices last summer, I decided to try to make my own. I am very happy with the result - I think it does not look much different from the $1,000 variety. The cost was less than $250 BUT - Since my boat is used in fresh water, I used galvanized electrical metallic tubing ($3 for a 10 ft stick, 3/4"dia.)and yes, I know what people think about galvanized on a sailboat! The fabric is sunbrella ($11.25/yd, 46"wide. The tubing is easy to bend with a borrowed tubing bender that all electricians have, or you can buy one for $50. End fittings are nylon from boat/us, with the I.D. increased slightly to fit the tubing. I sewed the thing on an old home sewing machine, using thread from Sailrite. Coaxing the machine through 4 layers was a pain, but it did the job. The hardest part was getting the fabric to fit tightly over the frame. The easiest part was bending the tubing. If the galvanized doesn't hold up, I'll either paint it or use aluminum. My boat is a Hunter 34. Any questions, tou can e-mail me at farlaef@aol.com. I'll be here until Jan 1, at which time I am going to Bradenton for a month.
