Desperately in need of a solution for a vibration-ratlling-thumping when motoring at certain RPM on my CAL 2-25 with Yanmar YSM-8hp. I first thought problem stemming from cutlass bearing, prop shaft or even engine mounts. Changed cutlass bearing, corrected shaft, replaced engine mounts. Problem now nailed down to what seems to be vibration between rudder shaft and rudder tube. Tried inserted Mylar sheets between post and tube which did not work (the sheets were swept away). Anyone with similar experience and solution!!!
