When replacing the original winches with self-tailing ones 3 years ago I mounted one of the old ones to the starboard coach top, I also mounted a triple clutch assembly forward of the winch. As pointed out, the roof construction on my boat, V-1874, has a foam core. I used 1/4 inch Starboard, the white plastic board available at Boat US, cut to size, round for the winch and rectangular for the clutch, using S.S. 1/4 in. screws and cap nuts.
One point of caution though, the starboard side has a light switch inside and an electrical conduit pipe as part of the skin/core sandwich right about where the winch mounts.
The payoff is that I have the main halyard, forward and aft reefing all led to the cockpit (I currently only have one set of reef points). That, in combination with the furling Genoa, makes things a lot easier.
I'll try to post some pictures when the weather is better, maybe in a couple weeks.
Hans Heiduck
V-1874, "Flicka"
