I found the overhead support for main cabin door pulled loose on stbd side on 79 H27. It hangs down about one inch inway of celling radius fare stbd side and gap tappers closed in direction towards compresion post. Port side is snug fit. It looks like cross piece holding door no longer square with compression post. Something shifted or racked. Area is dry all around and post is solid. The result is door pinches on opening all the way. Should I fix wood work or plane bottom of door or is this not unusual on 30 year old boat? No sign of stress on fiberglass headliner. Previous owner made core repair to cabin top but to what extent is unknown. Anyone encounter same? cheers ......frank
f
f
