C
CHET P
WELL IT HAD TO HAPPEN *CRY .... LAST WEEKEND WHILE OUT SAILING I WENT BELOW TO USE THE HEAD AND GET SOME COLD BEVERAGE THE BOAT LEARCHED AND I FELL AGAINST THE TABLE IN THE CABIN AND IT SPLIT IN HALF. I HAVE OFTEN CONSIDERED REMOVING IT ANYWAY AFTER READING GENE'S WRITE UP ABOUT RAINBOW CHASER, BUT WAS WAITING UNTIL I REMOVED THE MAST TO DO IT. WELL IT'S IN MY GARAGE NOW SO I AM LOOKING FOR ANY IDEAS ABOUT ANYONE WHO HAS DONE A MODIFICATION TO THE TABLE ARRANGEMENT. GENE I HAVE FOLLOWED YOUR PAGE FOR YEARS NOW (EVEN BEFORE I PURCHACED HARRIET'S CHARIOT) BUT DON'T QUITE UNDERSTAND HOW THE TABLE IS HUNG ON THE WALL... IT APPEARS THAT YOU HAVE TO MUSCLE IT OFF THE WALL AND HANG IT ON SOME WALL BRACKETS AND THEN SUPPORT IT WITH A LEG. I AM CONSIDERING BUILDING A BOX OFF THE BULKHEAD AND HINGING IT OFF THE BOX... I WOULD MAKE THE BOX A STORAGE CABNET FOR INTOXICATING LIQUIDS AND GLASSWARE FOR SAME. I DID THIS IN A CATALINA 30 I HAD THAT HAD A TABLE THAT NEEDED 2 MEN AND A BOY TO SET UP. I AM ALSO CONSIDERING REPLACING THE FLOORING IN THE MAIN CABIN DUE TO THE FACT THAT HURRICANE CHARLIE MANAGED TO PUT ENOUGH WATER INSIDE THE BOAT ON THE CABIN SOLE AS TO CAUSE MOST OF THE THIN LAMINATE TO DELAMINATE... I AM CONSIDERING RIPPING IT OUR AND USING SOME TONG AND GROOVE SOLID HARDWOOD AND GLUING IT TO THE FIBERGLASS CABIN SOLE USING 5200... ANYWAY AS OF NOW MY (MY WIFES ) MAIN CONCERN IS TO REPLACE THE TABLE..... ANY IDEAS OR PICTURES OF WHAT YOU DID??? THANKS
