Cabin sole
blunt
Jul 27, 2015
85
1980 hunter 33 Corpus christi
We pulled up our teak and holly sole.what we found underneath looks like a silicone glue.no screws holding the floor down.we know we have to scrape it off.is there anything out there too help break the bond for scraping?
Feb 20, 2011
8,062
If you type "caulk remover" in that quick search box in the upper right, you'll have some reading to do. ;)
blunt
Jul 27, 2015
85
You are right.goo gone mineral spirits denatured alcohol.so many choices not enough time.lol.will try what's works best,always have elbow grease.
SFS
Aug 18, 2015
2,091
Currently Boatless Okinawa
Somewhere on this site in the past two weeks or so, I read that there is a new high tech remover (possibly by 3M) that will actually remove 5200. Can't seem to find the thread.
blunt
Jul 27, 2015
85
Dynamite? Just gonna scrape and scrape and scrape.thank you for the info.
Dec 28, 2015
39
O'DAY 322 Bridgeport CT
BL, I just used a product called RE-Mov to lift the sole plywood on the ODAY. There were no screws only adhesive holding it. All previous attempt had failed as the wood broke apart first. Sprayed the product, waited a few minutes and it broke the bond.
I sprayed and worked it up from the center eventually got the entire 8ft piece from v berth to nav station out intact. I read about this stuff in Practical Sailor. Recommended!
Likes: Mickstr
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
If you already have the wood up you might want to try an oscillating tool with a scraper blade or an abrasive blade.
RoyS
Jun 3, 2012
1,742
Considering the same job on my 1980 H33. Please report on your progress and provide recommendations.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
What's under the plywood? Is it Fiberglass? Our Morgan 28 only had 3/4" ply bridged across the bilge and epoxied to the hull on either side. Then the teak&holly ply was glued down with mastic glue. What a mess! Once the subfloor rotted the whole thing had to come out.
FWIW I've heard that silicone is damned near impossible to completely remove. Maybe you'll have some luck with that Remove stuff? Please let us know...
blunt
Jul 27, 2015
85
actually our step son used goof-off and it removed most of the glue.just some stubborn spots left.but I will try the re-mov for these stubborn spots.thanks for the heads up.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
I have had luck with West Marine Anti-Bond 2015 on 3M 4000 / 4200. I am not advertising, just saying the stuff worked for me. Unfortunately, the only place to sell it is WM, and they charge handsomely. Fortunately, you don't need much.
Salty
Dec 2, 2008
144
Catalina 390 14 Perth Amboy, NJ
BwWhisper, I am curious, what did you use to replace your floor? I am looking at replacing my floor but I haven't decided the replacement yet. I am looking at using a teak & holly with the veneer pattern from Jamestown Distributors. The problem is it only comes in 8'x4' panels, which means I have to buy 2 panels even though I only need about 1.25 panels.
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Hey Salty, is this Patrick or John? It's Mickey... I'm going to try and remove the varnish, sand and re-varnish my cabin sole on my 322 before launch. If it doesn't work out, maybe I'll go in on some material with you!
Salty
Dec 2, 2008
144
Hey Mickey,
Sounds good. I cannot re-varnish because the section of floor by the companion way is not re-usable due to moisture and rot
Likes: Mickstr
Dec 28, 2015
39
I too partnered with another owner and bought 3 sheets of T&H plywood. My sole was stained from fuel we think but once removed was delaminating underneath.
