cabin lights
Mar 6, 2015
3
benteau 36cc placida, fl
all cabin lights are aqua-signal halogen. would like to switch to LED. is this possible? what is the trick to removing the lens without damaging?
Nov 24, 2012
586
This has been covered in previous posts. Not sure of the exact model you have but the most common cabin lights have a removable lens that simply twists a 1/4 to remove. Believe it's a g-4 led replacement. Many B owners have done this- it's a simple task
JRacer
Aug 9, 2011
1,365
I replaced all my fixtures because they were yellowing from age with the marinebeam fixtures that have the switchable red/white LED light. Very pleased with the outcome and marinebeam support. There is a difference between voltage regulated LED's and the lower quality products generally available on the net. Www.marinebeam.com is where to look. He also sells the LED replacement "bulbs" if your fixtures are OK.
arf145
Nov 4, 2010
495
Beneteau 331 Deale, MD
Replaced all my cabin bulbs with Marinebeam LED replacements. Very happy with the results.
May 7, 2014
135
Beneteau 390 Tiburon
Me too, all reading spotlights and ceiling lights changed over from G4 bulbs to warm light LEDs. Around $20 each both worth it in the long run
