Thanks to everyone who replied re: cabin lights wiring. I have found and
corrected the problem. After considering what everyone said and thinking
through the logic of it, I made a couple assumptions about the existing
wiring at the old fuse blocks. I assumed that only positive leads were
fused--but checked this first by putting a voltmeter on each to make
sure none were grounds. Then I determined which were not live positive
leads with the voltmeter and found the dead one. When I ran a live
positive to it, the lights came on. Somewhere there was a break in the
positive feed to that circuit. Easily fixed. Now, just to be safe (and
to learn how much current each and every electrical item on the boat
draws), I plan to put an ammeter between the battery and the main
circuit, turning on each thing one at a time to measure its draw. By
comparing these amperages to the predicted draws (from manuals for
various appliances, and the wattages of the various lights, etc.) I
should also be able to find any suspiciously high draw on any bad
circuit--to discover, for example, whether I did a poor correction of
the lights circuit. What fun! I still have a rat's nest of old wires to
clean up, but I've found almost everything now and rewired (and labeled)
all circuits to new fuse blocks and switches.
