They are Daisy chained
The wiring, at least on mine, was daisy chained from light to light. It isn't one continuous wire, but seperate wires between each light. Each light has 4 wires, two hot and two ground. They connect to the light, one pair coming in and one pair going out to keep the chain going. Corrosion on any connection will kill the lights downstream.I would check the connection at the last light that works, then work my way on down.The bigger problem is that Hunter used normal, non-tinned wire. It's not going to last too long. In addition, even if you do get the connections going, you'll find that each has a lot of resistance. When you get the lights going again try this. Turn on the v-berth light. It's far down the chain. Have someone turn on a main cabin light while watching the v-berth light. I'll bet it dims a lot. Hard on the eyes, and a waste of electricity.My solution was to run a continuous pair of 12 gauge wires down each side of the boat. Good, marine tinned wire. Then, without cutting them, I skinned back the insulation at each point I wanted a light. Wrapping a wire to go to the light around the skinned main run, then soldering and insulating each, I got very good connections and no light coming on effects any other.Good luck.Gene GruenderRainbow Chaser
