I'm trying to trace the cabin wiring in the 1978 Catalina C30. The cabin switch on the fuse panel operates only the light located in the galley which according to a diagram is the first fixture on the wiring run (removed fixture only has one pair blue and black wire) must have a junction some where and I've looked in all the nooks and crannies with no luck? Wiring harness behind fuse panel don't seem to have all fixtures home-run and would be wired in parallel. Total lights inop are the Sette, Head, Two V-berth, Chart Table and 1/4 Berth. Hate to have to run new wiring! The only docs I have found was the wiring diagram on page 12 of a Catalina 30 Owner manual.
