Apr 8, 2009
17
Hunter 376 Chesapeake Bay
Has anyone else had a leak along the upper starboard wall of the stern cabin? We reseated the stanchions, but find water in the storage alcoves above our bunk on the starboard wall. Can't figure out if it is a deck leak forward that travels back along some channel, or what?
Anyone experience this?
thanks!
Dry it out. Sprinkle some chalk about the cabin hull sides. Then, as @Don S/V ILLusion shares, hose it down.
You can also post pictures of the boat's outside (deck and hull). Someone may spot something that looks suspicious.
I know it goes against all logic and physics, but on a boat, sometimes water creeps uphill.
Apr 8, 2009
17
The chalk idea sounds good. She's on the hard now under cover, so I will post pics when the cover's off, but can run the chalk test. Wondering if anyone else has had this issue. Sometimes in a hard rain, nothing. Other times I find water. Thanks, Don and John
duck21
Jul 17, 2020
197
Hunter 376 0 Washburn, WI on Lake Superior
I had this same issue on my 376. We re-sealed the frame gaps on the aft cabin ports, that took care of the problem. The water was leaking through the port frames down onto the headliner then making its way over to the headboard. We used a little tool to scrape out the dried out sealant and resealed with black 4000UV.
I found details (and the recommendation on the fix) here:
Lewmar Old Standard Openers - known leaks
Otherwise, if you have Bimini hardware that may also be just above that area, you may double check bedding.
Doug
Apr 8, 2009
17
Thanks, Doug! That sounds like the same situation as ours, and the one fix we haven't tried yet.I really appreciate the link!!
Hunter 34 Herrington South, MD
We had a leak in our rear cabin. It turned out to be leaking through the chrome footing piece at the bottom of the pedestal guard. When the wiring for the chart plotter was installed, a hole was cut in the chrome footing to allow the wire to pass through below decks. Apparently, water was seeping under the footing or down the chrome piece and then through the hole cut for the wires.
Jun 10, 2018
1
Hunter 36 Chicago
I had a similar issue in my 2005 36. Check under the cockpit floor. There are several locations where wiring and the autopilot arm penetrate the sides under the floor panel that provide an easy path for water to enter. Just remove the screws in the cockpit floor and the floor panel will lift out. I sealed up those penetrations and fabricated a better seal for the autopilot arm and that stopped the leak for me.
AndyL
Jun 23, 2020
151
Hunter 36 Rock Hall
We had a leak that came out at the rear bulkhead in one corner of the aft cabin - it was from one of the six screws that hold the floor panel that Captdan67 mentions above. We found it by removing a ceiling panel in the aft cabin, above the centerline of the rear bed then running a hose over the cockpit floor.
