I second Eric on the pot, but...
...you can also use an unglazed garden variety Walmart flowerpot. As long as it has been fired once, it should be fine and they throw off quite a bit of heat even with a non-pressurized alcohol stove. Just stay away from "greenware" (unglazed pots for decorating and firing as a hobby).All ceramic pots have the potential to explode when heated, even glazed and rated for the oven. Usually they will just crack and still be usable. This happened a few months ago to some friends of mine that are first-time sailboat owners (Hunter 24, mid 80's vintage). I shared this inexpensive heating system tip with them and they tried it. The unglazed pot cracked right off, but has continued to be servicable. This is the first time I have heard of (or experienced) a crack in a flowerpot heater first hand, but it obviously happens, and I have read of it happening.The first time you fire it up (so to speak) you might want to be outside the cabin, just in case (I've started adding this advice since my friend's incident). I'll be adding a flowerpot heater to my new (to me) '79 H27 this fall and I'll season the pot while in the cockpit, just in case.
