John
I want to install a cabin heater in my O'Day 27 so I can do some coastal cruising this winter. I'm considering installing a propane stove and a propane cabin heater, or an alcohol stove and I don't know what kind of heater. I like the alcohol stoves but propane seems to be the way to go for cabin heat. I also like the idea of staying with one type of fuel for both. I have a gasoline Atomic 4 engine but I doubt that gas is a good option for a cabin heater fuel. I don't think diesel is a good option since I don't like the smell and I don't have it on board for anything else.I would like opinions on the following questions:1. What are the Pros and Cons of the different fuels? Alcohol, Diesel, Fuel Pellets/Charcoal and Propane.By the way, I've read the alcohol stove discussion, and I am Not trying to start a fight about fuel and safety. I know propane is dangerous and therefore expensive to install safely.2. Which fuel provides the most heat for the cabin?3. Which is the most economical fuel to use?4. Which is the most convenient fuel to use as far as lighting? As far as refilling?5. Which fuel is the easiest to purchase and get back to the boat while cruising the Gulf and Atlantic coast of Florida and the Bahamas?6. Are there any alcohol cabin heaters on the market? Who makes them? How will do they work?I'm familiar with alcohol stoves and I like the simplicity of them.7. What brand and model cabin heaters do you recommend?8. What safety suggestions should I consider? What ever I do, I will have a carbon monoxide detector on board and if go with propane I will install a gas detector.9. The trip starts in October from Southern Lake Michigan. Down the Illinois Waterway (I'll have to un-step the mast) to the Mississippi, up the Ohio and Tennessee Rivers and then down the Ten-Tom Waterway to Mobile, AL. Then on to Florida and who knows where. Anybody want to go?Thanks in advance for all the good advice.JohnS/V DragonFly
