Cabin Drain
RJ
I have a hunter 23. There is a drain inside the cabin. It is full of water (fresh water from when I cleaned the outer hull). How do I drain this water. Is there a clog somewhere? Also, where could the water be coming from? THX
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
If you mean the space under the floorboards...
...the easiest way to get the water out is with a bucket and sponge. There are several places where the water could be coming in and the usual suspects are in archives. The easiest way to find the leak(s) is to pressurize the cabin with a leaf-blower, then mop soapy water all over the deck and see where the bubbles form. Details of this method are also posted in the archives. Good luck. Peter S/V Raven
