If the boat is out of the water this can be caused by flex in the hull and would probably be ok once the the boat is back in the water.If in the water, then some adjustments need to be made.
try relaxing the stays and shrouds. it would be best to use a gage, but you can do it by hand. sometimes in the winter, the temperature will shrink the stays and shrouds, which can cause the boat to take a banana shape.
