:cry: Every year, for the last five years, I've had to repair cracks, and leaks in both the leading and trailing end of my '80 C30 rudder. At the end of last season, I drilled two holes in the bottom (after a recommedation) in hopes that any water would drain out. I just inspected the rudder and still have crackes with brown goo coming out of the same area of the cracks I've sealed the at the start of the season. I'v tried to seal the top of the rudder and around where the rudder post exits the top, only to be back to the same old problem. I'm worried that the thing will just fall off! Any way to stop these cracks/leaks and dry it out? Help?
