Has anyone added a pair of winches to the stern of this boat?Is it possible to run a wire up the mast (internal!)for wind indicators without unstepping the mast?
actually you will need to run the wire down the mast. you cas climb the mast and find or drill a hole for the wire and use one of the halyards to tie to and pull the wire down. if you are in luck when the stepped your mast they left a nylon line inside that they use to run wires. a local rigger might be the best solution though.
